Goodman CK36-18 Problem - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-04-2010, 08:30 PM   #16
Originally Posted by hvaclover View Post
yeeaahhhhh...
Lol,it's true! I also have an associates degree in electronics but I guess I'm not very good with ac circuits.
j66996 is offline   Reply With Quote
Old 09-04-2010, 08:51 PM   #17
hvaclover is offline   Reply With Quote
Old 09-04-2010, 08:52 PM   #18
Lol, no not him!!
Old 09-05-2010, 04:08 AM   #19
An old Tradesmen
Rewards Points: 7,816
Assuming a loss of a common he would have got 24 on only one side if he checked it the way you you describe.
No. He would still be able to read to ground on both sides of the contactors coil, since the coil is good.
Old 09-05-2010, 04:09 AM   #20
An old Tradesmen
Hi beenthere,
You are correct...I was measuring to ground. I get 0v when I measure across the coil. Where do I go from here?
Loose low voltage wire in the air handler, broken wire between the condenser and air handler, etc.
The Following User Says Thank You to beenthere For This Useful Post:
j66996 (09-05-2010)
Old 09-05-2010, 05:25 AM   #21
Thank you beenthere...I will check those things.
Old 09-05-2010, 10:14 AM   #22
Thank you thank you thank you!!!!!!!! You guys are the best! It looks like a squirrel chewed the wire where it enters the attic. I replaced the wire and am sitting in coolness! I really really really appreciate all your help and patience! Thank you!
Tammi
Old 09-05-2010, 10:59 AM   #23
An old Tradesmen
Congrats, and stay cool.
j66996 (09-05-2010)
$1440+ labor only repair on 3 yr. old Goodman unit!?! JMK HVAC 23 05-06-2012 10:45 AM
Weed problem, bug problem, or both? hayzen Landscaping & Lawn Care 1 08-25-2009 06:33 PM
Goodman Gas furnace, A/C will not run new install RCApp HVAC 5 08-04-2009 09:00 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
