Goodman CK36-18 Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 08-13-2011, 02:44 PM   #1
Goodman CK36-18 problem
My AC has been running almost constantly this summer here in Texas. Today, I noticed the compressor tries to kick in but stops after a seconds. The relay is actuated with voltage on both the line side and compressor side and the cap and contactor were new last fall. Has my compressor bit the dust? Thanks!
BTW The fan runs fine
j66996 is offline   Reply With Quote
Old 08-13-2011, 03:17 PM   #2
JJboy's Avatar
You should test the run and start capacitor again
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
j66996 (08-13-2011)
Old 08-13-2011, 03:30 PM   #3
Thanks JJboy...how do I test it?
Old 08-13-2011, 04:00 PM   #4
JJboy's Avatar
Do you have multimeter?
Old 08-13-2011, 04:06 PM   #5
Yes but it doesn't have a capacitance checker on it
Old 08-13-2011, 04:20 PM   #6
JJboy's Avatar
You need one meter with MFD. Radio Shack has very cheap under $10
j66996 (08-13-2011)
Old 08-13-2011, 04:22 PM   #7
Thank you, I'll go grab one from work and let you know what I find.
Old 08-13-2011, 05:58 PM   #8
I just checked the cap and it's bad. It's supposed to be 45 and 5 MFD and it reads 6.8 and 5. Thank you so much for your help JJboy!!
Tammi
goodman gmpn100 venter problem lucydisguised HVAC 8 02-17-2011 07:37 PM
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 07:35 PM
Help Carrier, Briant Furnance with Variable motor problem ahenderson HVAC 1 12-19-2010 01:07 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
