Goodman CK30-1B - HVAC - DIY Chatroom Home Improvement Forum
Old 08-25-2009, 07:15 PM   #1
Goodman CK30-1B
Condensor will not take a charge. Tech said probably the valve in compressor is bad.
Should I replace condensor or get another opinion?
typhoon55 is offline   Reply With Quote
Old 08-25-2009, 07:19 PM   #2
30 year tech
hvac122's Avatar
Need alot more info than that to help. What were the pressures? Superheat, subcool? Compressor amps?
hvac122 is offline   Reply With Quote
Old 08-25-2009, 07:55 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,274
Did he call it a relief valve? If that blew and is stuck open then the compressor is shot. Otherwise if he weighed or measured the refrigerant in to the factory specs and it won't build up the proper pressures the valves could be worn out. Need more info. If he said "Probably" then get another opinion and don`t tell the next guy what the first one said.
Old 08-26-2009, 09:53 AM   #4
HVAC / Plumbing
Unless you want to spend alot of $ to replace everything... U could just replace comp
kenmac is offline   Reply With Quote
goodman HVAC problem...only runs on AUX mode kerbear413 HVAC 1 12-02-2008 11:51 PM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 12:43 PM
goodman furnace nhicks HVAC 3 02-09-2008 06:25 PM
Replacing an 20 year old gas forced air with a 95% 2 stage goodman, goodman 40" tall, englewood1 HVAC 12 09-25-2007 11:37 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
