Goodman Circuit Board Help - HVAC - DIY Chatroom Home Improvement Forum
Old 08-29-2011, 05:33 PM   #1
goodman circuit board help
I am looking for a circuit board for a goodman unit PGH048100-1 part number B1809905. I have found every number but that one. I would even take a broken one or a used part for this as I can get the circuit board fixed I just need one to start with. Can anyone please advise where I might find this? I would appreciate any help I can get. Thanks Melissa
melissamcclain is offline   Reply With Quote
Old 08-29-2011, 06:03 PM   #2
JJboy's Avatar
Is it the circuit board or a dual fuel control board?
http://icpindexing.toddsit.com/docum...2104130100.pdf
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-29-2011, 06:05 PM   #3
goodman
different sites show different names most call it a circuit board but some are calling it a control board
Old 08-29-2011, 06:10 PM   #4
biggles's Avatar
check this one or other brands they don't make their boards might be honeywell..last number might be production code not critical... http://www.bestbuyheatingandaircondi...ode=CIB1809913
The Following User Says Thank You to biggles For This Useful Post:
melissamcclain (08-29-2011)
Old 08-29-2011, 06:32 PM   #5
AKA HVACTECHFW
Rewards Points: 1,208
See the answers here.............
http://www.justanswer.com/hvac/5gdas...h048100-1.html
this is the board you are needing.. It is a dual fuel board. you have a heat pump with gas backup all in one unit.
http://www.furnacepartsource.com/dls771.html
here is a parts breakdown of your unit for future reference.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 08-29-2011, 07:09 PM   #6
hvactech
hello I spoke with you on just answer. I was hoping that someone would find the actual old board that fits my model. I spoke with Goodman and they say that this part is obsolete the b1809905. If thats the case do you think the part 117166 still work on my unit? I have a friend coming Wednesday to look at my unit but I am going to see if he can look at the board to get any other numbers off of it he can. thanks again for the info and please advise if you can on the part being obsolete.
Old 08-29-2011, 07:17 PM   #7
JJboy's Avatar
Ask Goodman for the new part number or the correct replacement
Old 08-29-2011, 07:20 PM   #8
AKA HVACTECHFW
compare the pic to your board......................it may not be exactly the same, but if it has all the correct terminals........... It should be direct replacement though......
IT IS WHAT IT IS
The Following User Says Thank You to hvactech126 For This Useful Post:
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
Goodman furnace control board patz83 HVAC 7 03-14-2010 03:07 PM
Lennox G20 Series - Bad blower board - or is it more? inn8pwr HVAC 48 12-30-2009 05:13 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 11:03 AM
