Goodman A/C Doesn't Turn On - HVAC - DIY Chatroom Home Improvement Forum
Old 08-10-2013, 08:36 AM   #1
Unhappy
Goodman A/C doesn't turn on
Hi, I recently bought a new house and my second week in one of my two Goodman gsx130241 units does not start. I scoured Google and checked to see if there are any quick checks and fixes before I call for service.
When I set the thermostat on nothing happens. I went outside to check if there is a clicking noise and I didn't hear anything. I compared it to the functional unit and I heard everything kick off instantaneously. I then checked to see if it was the thermostat by replacing batteries and also manually combining the red and green wires then flipping the breaker on and nothing happened.
What's my next move here?
ielkind is offline   Reply With Quote
Old 08-10-2013, 08:50 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
Verify you have 240V at the line side of the contactor?
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 08-10-2013, 08:59 AM   #3
Rewards Points: 12,912
Did you check the breaker to see if it's off?
There may be two different two pole breakers.
Also look on the outside of the house for a disconnect. Open the cover to see if the disconnect is in place and right side up.
http://www.amazon.com/Siemens-WN2060...d_sim_sbs_hi_1
The bar to disconnect it can be removed so the unit can be service and flipped over and put back in so it does not get lost.
Old 08-10-2013, 01:40 PM   #4
Experienced HVAC Tech
HVAC1000's Avatar
R and G wires are just to control the fan at the air handler/furnace. You need to also put the Y wire (and possibly B wire also (if heat pump)) before you can even start the troubleshooting. Of course the outdoor unit won't turn on if u don't give it a signal to
HVAC1000 is offline   Reply With Quote
Old 08-10-2013, 04:16 PM   #5
The air blower is working when I turn the fan to on. I checked the disconnect and made sure it was snug (it was) (and right side up) and I checked and retested the moisture check on the blower. Still no go. I don't have a meter to check the voltage.
Old 08-11-2013, 02:53 AM   #6
HVAC1000's Avatar
Go buy a meter then check if u are getting 24 volts (its only 24vac dont be scared) at the contractor in the outdoor unit. Then report back. There are a few more things to check next
Old 08-11-2013, 07:28 AM   #7
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Check your AHU drain pan and make sure that it's not full of water.
wirenut1110 is offline   Reply With Quote
Old 08-13-2013, 01:48 PM   #8
I called a technician and he found out there was a short in the compressor. At least it didn't cost me an arm and a leg!
Old 08-13-2013, 11:10 PM   #9
HVAC1000's Avatar
Ya now your new compressor or new condenser once installed will only cost you an arm
Old 08-13-2013, 11:11 PM   #10
HVAC1000's Avatar
Sorry double posted it
Bad home wiring? Turn off light-internet drops or motion light turns on drewryjams Electrical 2 07-30-2012 04:55 PM
Jacuzzi won't turn off hand_in_ga Electrical 3 06-17-2012 08:23 PM
Help with a faucet that won't turn on\off OhmZoned Plumbing 1 06-17-2012 10:05 AM
Cant turn shower nob to turn on shower GeoffStone Plumbing 5 04-25-2012 09:09 AM
Faucet won't turn off etiger Plumbing 1 08-31-2005 03:46 AM
