Goodman - Blower Quirks - HVAC - DIY Chatroom Home Improvement Forum
Old 11-26-2007, 11:55 AM   #1
I have a goodman GUN furnace from early 90's. It has a symptom that has come up that has me puzzled. The air conditioning works fine in summer. When the furnace calls for heat the induction blower turns on, and runs forever, then the heater will light and run but not for more than 2-3 minutes then the cycle starts again. The furnace will not keep up with the heat demands doing this. If I turn the blower to the on position on the thermostat instead of the automatic setting, the furnace will run as it should and heats the house up within 5-10 minuts. Does anyone have any ideas what to check?
wagsterracer is offline   Reply With Quote
Old 11-26-2007, 09:57 PM   #2
Do you notice a difference in airflow out of the registers when the fan is in auto vs. manual fan? If you do, in auto, heat calls for the low fan speed and with the fan in the on position it calls for a higher speed. I have had the situation where one fan speed burns out or operates at a slower speed than it should and overheats and cycles the furnace. On one furnace with this problem, I just switched the fan speed to a higher speed and its been working fine for the last five years.
shawn T is offline   Reply With Quote
Old 11-27-2007, 10:20 AM   #3
Blower Speed
There does not seem to be a substatial difference in the airflow. The thing that confuses me is the induction fan will run 5-10 minutes before the furnace will fire and turn on the main blower. If the furnace calls for heat and I immediately turn the blower to on instead of auto, the furnace will fire within a minute and cycle normally.
Old 12-03-2007, 06:23 AM   #4
Sensor
Could the sensor that senses the draft inductor be going out? And would the blower being on make enough pressure difference to let it run normally?
Comfortmaker blower intermittent problem jh44ny HVAC 12 07-31-2011 06:41 PM
Heat comes on but blower never does aczer HVAC 12 02-13-2011 06:57 AM
Blower control board mlmaher HVAC 1 11-24-2007 01:39 PM
Goodman HVAC gmp100-3 Inside blower problems ray_adrea HVAC 4 06-28-2007 12:31 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
