Goodman Blower Cycling On And Off With No Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 10:13 AM   #1
Goodman Blower cycling on and off with no heat
I have a
Goodman GMH81155CN Gas Furnace
115,000 BTU Furnace, 80% Efficiency, 2-Stage Burner, 2,000 CFM Multi-Speed Blower, Upflow/Horizontal Flow Application
as of last night these have been the symptoms:
1 click
2 click
3 click - RED LED at the bottom motor circuit board comes on
4 click - RED LED is still on
5 click - sounds like a double click and exhaust motor comes on the RED LED is still on, but after 2 - 3 seconds the exhaust motor cuts off, RED LED turns off, and the cycle repeats after about 2-3 seconds.
The unit is less than two years old, no wires are loose anywhere, everything looks clean and dandy on a visual inspection.
Please assist
bcarter is offline   Reply With Quote
Old 10-18-2010, 10:24 AM   #2
HVAC / Plumbing
Is hsi glowing red? Unit has 5-10 yrs parts warranty. What is your labor warranty ?
kenmac is offline   Reply With Quote
Old 10-18-2010, 11:34 AM   #3
Hi
The HSI doesn't glow at all.
I switched off the heating functionality at the thermostat control, then went back to the unit to pull these fault codes:
3 - pressure switch stuck open
4 - open high limit
I see the pressure switch on the blower body, took that off not sure what im looking for, it looks functional moves in and out freely.
With the open high limit i dont have the proper tools nor the knowledge or capacity to jump it to diagnose it further.
thanks for your help so far any additional input would be great.
Old 10-18-2010, 01:18 PM   #4
HVAC / Plumbing
If you don't have the knowledge or the tools to check . I would call the installer & find out why the limit opened. You may have warranty & if you tinker with it he may void your warranty
Old 10-18-2010, 01:41 PM   #5
Thanks for the follow up
I used this site to check the high limit switch
http://www.ihatemyfurnace.com/
according to this if i get continuity its functioning. I got continuity.
While i look for the info of the guy that installed this im going to just check things out, ie like blockage in tubes, continuity etc.
appreciate the help so far.
