Old 11-05-2011, 06:31 PM   #1
Goodman 95% flue vent
I just installed a 95% goodman gas furnace.For venting I have a 3" tee on the end.I was wondering if i could use a gas vent cap like this one
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
or would it cause a problem?
marknn1985 is offline   Reply With Quote
Old 11-05-2011, 06:37 PM   #2
I'm Your Huckleberry
If you're talking about the pvc intake and exhaust, no. I think that the flue vent is type b metal and should be 4" if I'm not mistaken. That cap is for the metal exahust (burned gases) vent.
Maybe someone with more experience with condensing furnces will chime in but I'm going to say no.
Doc Holliday is offline   Reply With Quote
Old 11-05-2011, 06:47 PM   #3
The "T" fitting is the termination, you shouldn"t have to put anything else onto the vent termination. Adding additional fittings can cause freeze ups of the vent, and additional resistance to the venting system.
HVACDave is offline   Reply With Quote
Old 11-05-2011, 06:47 PM   #4
Yes sorry it is for the flue vent.Can i use anyother type of cap other than the tee cause it sticks over the top of my house and it looks funny.thanks for your help
Old 11-05-2011, 07:49 PM   #5
Hvac Pro
You have plastic venting for a high efficiency unit. Cannot add anything to it and must follow Goodmans venting guidelines or it will develop pressure switch tripping problems. A fake owl is a good idea on top of it to keep small birds from nesting in it. No lie.
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 06:47 PM
gas hot water tank vent & chimney flue trees HVAC 11 10-16-2009 10:23 AM
Goodman GMP-075-3 Vent Fan nbaker HVAC 5 11-08-2007 09:52 PM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 11:28 AM
