Old 02-10-2011, 02:22 AM   #16
retired elect/hvac/plumb
plummen's Avatar
Goodman 6 flashes fails to light after fan
Originally Posted by HAMP View Post
Or maybe that little black thing in pic #4... that might have wiggled a little when the door was removed. It's part of the other door.
thats your door switch
plummen is offline   Reply With Quote
Old 02-10-2011, 02:25 AM   #17
plummen's Avatar
picture 1 is an inducer motor and pressure switch and vacuam line i was talking about,this is an 80% furnace but concept is same on 90 plus furnace just differant location.
Old 02-10-2011, 02:28 AM   #18
plummen's Avatar
in picture 1 on the top left side of burner cover the red wire closest to heat exchanger is the flame sensor wire
Old 02-10-2011, 02:34 AM   #19
HAMP's Avatar
So do you think that was my problem, those two yellow wires? Should I clean the tips? or do you have another idea?
HAMP is offline   Reply With Quote
Old 02-10-2011, 11:59 PM   #20
Ok so it's still happening...I double checked and it's actually an EIGHT flash error. If I look through the window I see that the ignitor never heats up when it fails to light and the gas doesn't come on. This leads me to believe that the issue is
1) lack of pressure build-up by the initial fan (is that the right term)
2) bad electronics which are sending bad signals
It still seems odd to me that a 30 minute power cycle resets it and then it works fine...any ideas?
barnis is offline   Reply With Quote
Old 02-21-2011, 10:08 PM   #21
anyone still watching this thread...it's cold and won't light at all now...wondering what I can do to get it lit...
Old 02-22-2011, 04:31 AM   #22
plummen's Avatar
time to call somebody local to you out there,only so much can be trouble shooted over a computer and a couple guys have already tweaked things on it.
if youre someplace close to omaha ne let me know
Old 02-22-2011, 12:59 PM   #23
HAMP's Avatar
I see your still having problems also. Mine is odd to me. When I took the door off it started working fine, when I had time later to put the door back on, it started doing it again.
I took the door off and it works. I know I can't leave it like this, but only time I think of working on it, is when it's too cold to have it off.
or the e-mail I got that reminded me.
Old 02-22-2011, 01:08 PM   #24
Did you find the rubber hose from the pressure switch to the inducer draft motor? Did you blow through the hose towards the blower housing and see if you can clear it? or take a small stick pin and push it through the prong sticking out of the housing to see if there was a blockage?
college A/C is offline   Reply With Quote
Old 02-22-2011, 01:35 PM   #25
HAMP's Avatar
Is this for me?
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
Weathermaker 9200 Ignitor fails to light Atomic HVAC 5 03-22-2010 12:59 PM
Pilot light button on furnace won't turn whydonchathen HVAC 5 10-06-2008 12:03 AM
Furnace won't light (Goodman GMP100-3) MattJ HVAC 8 10-03-2008 10:11 AM
Trane 80xl, 3 flashes error light - draft pressure problem, help? Xsta HVAC 1 10-14-2007 09:20 PM
