Goodman 3 Ton Condenser (ssx160361ab) With Goodman (CAPF4860C6) 4 - 5 Ton Coil ? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-30-2013, 07:06 AM   #1
Goodman 3 ton condenser (ssx160361ab) with Goodman (CAPF4860C6) 4 - 5 ton coil ?
I realize that this is an age old question.. but would still like to ask for current "schools of thought"
Is it ok to match a Goodman 3 ton condenser (ssx160361ab) with Goodman (CAPF4860C6) 4 - 5 ton coil and my Goodman GCVM960604cx 60,000btu furnace?
The AHRI shows it as a matched system, but wondered as to possible complications associated with the oversized coil ?
Is freezing up the coil a possibility? Any other issues I should consider?
Any help appreciated..
adaddo is offline   Reply With Quote
Old 07-30-2013, 02:29 PM   #2
Goodman's 16 and 18 SEER units get some of that efficiency rating by specifying large coils and TXVs.
I know the main match for my 1.5T 13 SEER HP is a 1.5-2T coil and the match for the 14 SEER 1.5T HP is a 2.5T coil.
Big coils and high CFM improve efficiency by operating at a warmer coil temperature, so freezing won't be an issue, but it's possible a smaller coil might dehumidify better. With your variable speed blower, you can always drop the CFMs if you want better dehumidification and it'll be quieter too.
taxmantoo is offline   Reply With Quote
The Following User Says Thank You to taxmantoo For This Useful Post:
adaddo (07-30-2013)
Old 08-01-2013, 04:27 AM   #3
An old Tradesmen
Rewards Points: 7,816
Big coils freeze up as easily as a small coil does.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (08-02-2013), taxmantoo (08-01-2013)
Old 08-01-2013, 10:40 PM   #4
Personally, I have used bigger coils and changed to correct piston/meter before. My thoughts are correct pressures with more cooling surface. Old school thought, only go half ton bigger on piston.
countingcoup is offline   Reply With Quote
The Following User Says Thank You to countingcoup For This Useful Post:
adaddo (08-03-2013)
New 410a condenser with old coil.... simeltzer HVAC 31 03-10-2013 05:39 PM
AC - Coil leaking fcabanski HVAC 7 07-04-2012 09:50 PM
Nordyne A coil, Goodman condenser. Want to install TXV. rdhill HVAC 2 04-26-2011 09:12 PM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 01:54 PM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 12:43 PM
