Goodman 3.5 Ton Condenser Fan Stuck - HVAC - DIY Chatroom Home Improvement Forum
Old 09-07-2008, 10:59 AM   #1
Goodman 3.5 ton condenser fan stuck
I happened to walk by one of my Goodman a/c units yesterday and noticed it was humming and hot, and the fan was not running.
I gave the fan a twirl with a stick and it started runniing.
My question is, do I need to oil the fan motor or replace the capacitor? or just replace the motor?
diyselfer is offline   Reply With Quote
Old 09-07-2008, 11:58 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Probably the capacitor. If the compressor runs, but the fan doesn't start on it's own, most of the one's I've fixed before needed a cap. A visual check is to see if the top or bottom is 'bubbled out'...typical sign of a blown cap on those units. If you have access to a capacitor checker, you can check it.
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 07:03 PM
Condenser fan motor/compressor kristeng HVAC 3 07-26-2008 12:02 PM
Replacing a Condenser Fan Motor (Goodman) guddug HVAC 8 07-03-2008 11:11 PM
Replacing an 20 year old gas forced air with a 95% 2 stage goodman, goodman 40" tall, englewood1 HVAC 12 09-26-2007 12:37 AM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
