GOODMAN 100-3 Forced Air Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 11-03-2010, 12:47 PM   #1
GOODMAN 100-3 Forced Air Furnace problem
Having problems with Goodman 100-3 forced air furnace. Ignitor will glow, burners begin to fire up...then it stops...restarts again like this 2 more times then stops completely. Replaced THERMOSTAT...same thing happens..Replaced FLAME SENSOR..same thing....however finally got it to run for 24 hours, thought it was working ok...then this morning woke up to cold house...back to where it once was...Status red light blinks 1 time with a 2 second delay between blinks. Any suggestions would be greatly appreciated!!
lindatbird is offline   Reply With Quote
Old 11-03-2010, 02:34 PM   #2
HVAC / Plumbing
check that ps is staying closed.. Check hose connection from ps to vent motor, check port where hose from ps connects to vent motor. Be sure small port is open at vent motor where ps hose connects
kenmac is offline   Reply With Quote
Old 11-03-2010, 11:42 PM   #3
Question
Ps?
I'm a bit confused...what is a ps?
Old 11-04-2010, 12:27 AM   #4
Thumbs up
oh..researched a bit...ps = pressure switch! gotcha
Old 11-10-2010, 09:55 PM   #5
AKA HVACTECHFW
Rewards Points: 1,208
sounds like a flame sensor dirty problem, clean flames sensor with steel brush or steel wool. and wipe off in clean rag , reinstall and check operation
hvactech126 is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Lennox Elite Series Furnace Problem steges HVAC 7 11-06-2010 03:49 PM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 01:01 AM
Goodman furnace problem ACB2 HVAC 5 01-13-2010 10:32 PM
Strange Problem with My Furnace chenjijc HVAC 14 11-04-2009 10:05 PM
