Goodman 100-3 - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 11:35 AM   #1
Goodman 100-3
How do i check for a faulty gas valve?
tnetten is offline   Reply With Quote
Old 11-08-2010, 01:37 PM   #2
HVAC / Plumbing
a very good sign would be. It the gv has 24v (on 24 v syatem)& it's not opening
kenmac is offline   Reply With Quote
Old 11-08-2010, 06:12 PM   #3
The valve goes from 0-24 than drops instantly back to 0 and the system shuts down.
Old 11-08-2010, 08:15 PM   #4
HVAC / Plumbing
check that the ps is staying closed
Old 11-09-2010, 07:12 AM   #5
I bypassed the ps to test and it did the same thing.
Old 11-09-2010, 10:35 AM   #6
HVAC / Plumbing
could be the board dropping 24v. You'll have to ck all limits are staying closed. jump the r to w at the t.stat & see what happens
Old 11-12-2010, 10:46 AM   #7
I ran a wire to jump out the rollout switches and got the same effect.
Old 11-12-2010, 12:15 PM   #8
HVAC Tech/Owner
Rewards Points: 604
flame sensor?
Technow is offline   Reply With Quote
Old 11-12-2010, 12:17 PM   #9
I removed flame sensor and cleaned it.
Old 11-12-2010, 12:43 PM   #10
HVAC Tech/Owner
Rewards Points: 604
Did you check the amps?
Old 11-13-2010, 02:52 AM   #11
Bad stat or Burners are shot. Time for a new furnace.
hvaclover is offline   Reply With Quote
Goodman air handler adjustment Xander08 HVAC 2 12-24-2009 02:32 PM
goodman 3ton dhop11 HVAC 2 11-14-2009 12:02 PM
Nordyne condenser goodman A-coil wtroger HVAC 10 09-16-2009 03:52 AM
goodman furnace nhicks HVAC 3 02-09-2008 06:25 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
