Goodman 100-3 - HVAC - DIY Chatroom Home Improvement Forum
Old 11-07-2010, 07:51 AM   #1
Goodman 100-3
I have a problem with my furnace not igniting. The pressure switch is working fine, but the flame will not stay lit more than a second. I cleaned the flame sensor and checked the gas valve. The light on the circuit board turns off as soon as the flame shuts off, with no flashing at all. The only way to get it to do anything is to reset power on the unit. The breaker is not tripping. Please help, my dogs are freezing and I can't afford to use space heaters all the time.
tnetten is offline   Reply With Quote
Old 11-07-2010, 07:58 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 386
Sounds like a bad circuit board or faulty ground from it to the furnace and furnace to ground.. Check for ground from the furnace to a copper water line with a cheater wire if necessary. If the board is mounted on a plate on the fan those plates come lose and lose grounding and blow the board. Need to put more sheet metal screws in it to tighten it up. Buy the board from a reputable dealer not Bubba on zbay.
Goodman air handler adjustment Xander08 HVAC 2 12-24-2009 02:32 PM
Nordyne condenser goodman A-coil wtroger HVAC 10 09-16-2009 03:52 AM
goodman furnace nhicks HVAC 3 02-09-2008 06:25 PM
Replacing an 20 year old gas forced air with a 95% 2 stage goodman, goodman 40" tall, englewood1 HVAC 12 09-25-2007 11:37 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 07:54 AM
