Old 03-07-2014, 09:23 AM   #1
Share |
Good hot air gas furnace?
Hi, I'm thinking of buying new hot air gas furnace and looking for the one that has good ratings. Popular ones are Carrier, Bryant, Payne, Heil, Lennox, Trane, York, Miller and Rheem. Any suggestion are most welcome. Thank you.
atun willis is offline   Reply With Quote
Old 03-07-2014, 09:37 AM   #2
Hvac Pro
They are all good. You cannot go by ratings as only unhappy people give ratings and a LOT of the time they are more upset with price or the contractor than the actual product. Miller is very entry level and does mobile homes and prefab homes. There are 3 grades of furnaces. Builders grade/entry level, regular grade and deluxe. All depends how quiet you want it and what features. Most good salespeople should be able to walk you thru that. Check references and with the BBB and make sure they do a heat loss calculation so they get the proper size. If they don't and won't show it to you kick them out and get one that will or DIY.
http://www.hvaccomputer.com/gtarget1...Fe4-MgodPF4AoQ
Old 03-12-2014, 10:41 AM   #3
Thx a lot Yuri...
Old 03-12-2014, 11:40 AM   #4
Hvac Pro
Yur Welcome
Old 03-12-2014, 01:12 PM   #5
If you are interested in a free calculator for heat loss/gain HOT 2000 looks pretty intuitive
HVACDave is offline   Reply With Quote
Old 03-12-2014, 03:13 PM   #6
Retired from the grind
gregzoll's Avatar
The Armstrong Air line from Lennox is a good unit.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 03-12-2014, 07:48 PM   #7
I thought miller was a Nordyne.
Patrick Eubanks is offline   Reply With Quote
Old 03-13-2014, 08:49 AM   #8
Hvac Pro
It is.
Older Trane 90xl Furnace Perry401 HVAC 1 11-15-2013 12:00 AM
Heil Furnace problem - is is the undersized vent? mpmusicny HVAC 8 11-20-2012 12:47 PM
Furnace running proper? Spydey HVAC 6 12-16-2011 07:57 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
