#1 |
Goldman air handler
Hi guys. Trying to find the model no for a goodman air handler. I see AR4B on the sticker. My research tells me there is no such model......AR48 would be more like it? Sure its a b though. What makes it even more bizarre is that I dug out the invoice and it says ar18....? I'm screwed if this is the case because I wanted a 4 ton....any help with model numbers?
Thanks Last edited by gkaro; 08-18-2011 at 07:02 PM. |
#2 |
Hvac Pro
Goldman air handler
18 would be 18,000 BTU which would be GROSSLY undersized and would never work with a 4 ton/48 condensor. Most manufacturers use a standard multiple of 6 or 12 in their numbers, ie, 24/36/48 = 2/3/4 ton and all the Goodmans I have seen are following that pattern so I suspect it is a 4 ton. Check the model # of the outdoor unit to be sure. Could also be that it is a 4 ton coil in a B size or they have different cabinet sizes. Lennox has 3 coil sizes A,B, C and they get larger from A to C being the largest. B is a mid sized coil. Reason they have 3 coils is the larger the coil the lower the resistance and pressure drop across it.
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by yuri; 08-18-2011 at 07:32 PM. |
#3 |
Goldman air handler
Thanks yuri. The cond. Is 4ton for sure. I need to get a 5kw heat strip for it and need to make sure I get the right one.
| Display Modes | |
| Air handler leaking | kcamnairb | HVAC | 4 | 08-17-2011 05:32 PM |
| SPace Pak Air Handler Wiring Question--208-230/60/1 | metal121 | HVAC | 5 | 05-07-2009 06:52 AM |
| Space Pac Air Handler Wiring--208-230/60/1 Volts | metal121 | Electrical | 4 | 05-05-2009 11:20 AM |
| Proper way to clean the air handler drain lines | lithium1330 | HVAC | 2 | 11-25-2008 10:48 AM |
| Replacing air handler - How to fit when form factors are slightly different?? | hennyh | HVAC | 2 | 11-16-2006 09:23 AM |
