Gmp100-3 - HVAC - DIY Chatroom Home Improvement Forum
Old 12-13-2012, 08:34 PM   #1
gmp100-3
starts the flame and after 3 seconds or so it stops. cycles 3 times and got a single blinking light. i steel wooled the flame sensor. didn't fix. just converted from nat gas to propane.. changed orifices and spring in valve. adjusted per directions. i don't have a gauge to measure pressures. i also don't know what the flame should look like. any help please.
jamescollier is offline   Reply With Quote
Old 12-13-2012, 08:41 PM   #2
Rewards Points: 582
you have to measure gas pressure....for sure after a conversion... also check for restriction in flue and or combustion air piping..ben sr
Old 12-13-2012, 08:52 PM   #3
Also need to clock the appliance to determine input.
Edit: just saw that you went from NG to propane. Clocking may not be possible.
hvac benny is offline   Reply With Quote
Old 12-13-2012, 09:29 PM   #4
gmp100-3
thanks guys. looks like the best way to go is to have someone come out and look at it. was trying to do it myself but i guess it is smarter than me :-P. will post back when i find anything else out.
The Following User Says Thank You to jamescollier For This Useful Post:
ben's plumbing (12-14-2012)
Old 12-14-2012, 06:39 AM   #5
smart move
mrairflow is offline   Reply With Quote
