Tried to turn on the furnace this morning and it would not kick on. Looked at the circuit board and the status light was continuously blinking. The error code means "incorrect primary polarity" or "incorrect twinning". I reversed the transformer's primary polarity and had the same issue, so I put them back. After sometime checking out the hardware, wires, ground connections, and board, I noticed some burn spots on the back of the board near the bottom right relay in the first pic.
The model board I have is 1012-83-9335A. See pics of board and burn spot, could this be the culprit??
Whats the best place to get a new board? If the same board model is not available, which ones are compatible?
