Gibson Furnace Won't Stay Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2008, 08:54 PM   #1
Gibson furnace won't stay lit
Hello I have a gibson gas furnace and for the last month when it needs to cycle on it ignites like it should but only stays lit for 5-10 seconds then goes out and this repeats 5 times and then shuts down. It does work sometimes but sometimes its several hrs before it will finally work. I have cleaned the flame sensor with sand paper but this didn't help. The led light on the swichboard flashes 4 times which means ignition problems. Any help would be greatly appreciated cuz i'm freezing
Srx70025 is offline   Reply With Quote
Old 12-19-2008, 09:00 PM   #2
Does it have an intermittent pilot or a hot surface ignitor.
SKIP4661 is offline   Reply With Quote
Old 12-19-2008, 09:19 PM   #3
Hot surface ignitor.
Old 12-19-2008, 10:35 PM   #4
Ok I think I figured it out.My furnace has four burners or burner ports whatever you call them and when my problem is occuring only two of these are lighting and when all four light my furnace works.I noticed that when all four do finally light the two that usually don't work have a weaker flame.Any ideas on what would cause this and how to fix it??
Old 12-19-2008, 10:40 PM   #5
The burners may be be partially plugged with dust and lint. They may need to be blown out or removed and cleaned. Removal is the preferred method.
Old 12-19-2008, 10:49 PM   #6
Ok I will try this. Thank you very much!
Lennox Furnace burner won't stay on stevea7777 HVAC 64 03-09-2017 05:39 PM
Ducane Gas Furnace fails to stay on franko HVAC 25 12-08-2011 04:14 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Furnace Wont Stay On mccheese82 HVAC 6 12-16-2007 12:11 PM
