Gibson Furnace Burners Don't Work - HVAC - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 09:09 AM   #1
Gibson furnace burners don't work
Hi, I have a Gibson furnace. When thermostat asks for heat, I can see the inducer draft motor starts up, pressure switch pulls in, igniter glows red, but the burners do not come on. I can also see the LED flink three times. When I push somewhere on the 9-pin connector on the control board with my hand, the burner comes on, but it goes out once my hand is off the connector. What is the problem? Please help!
rockyzys is offline   Reply With Quote
Old 12-21-2011, 11:32 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,260
bad connection or bad board or bad grounding of the board.
Old 12-21-2011, 12:55 PM   #3
Can you tell me how to check the board grounding? Thanks!
Old 12-21-2011, 04:58 PM   #4
HVAC Tech/ Browns Fan
That harness has wires goes through that part. Need take a part and make sure the wires are push into the harness. Sometime the great old cable ties can help
Tator1076 is offline   Reply With Quote
Old 12-21-2011, 06:10 PM   #5
Hvac Pro
yuri's Avatar
I would carefully remove that harness off the board and inspect the pins with a magnifying glass and see if any are pushed back. then reconnect it. not familiar with that brand but they all work the same ( within reason). there should be a green wire from that harness or the board which goes to the chassis of the furnace or metal mount the board attaches too. post a pic of the board and mounting. you can also with the power On and the door switch held in with the handyman's secret weapon (duct tape) check with a AC volt meter between the C terminal on the board and the neutral wire coming into the furnace. should get less than 1 volt reading. let me know if it is higher. if so the furnace may not be grounded properly. sounds more like a connection to the board problem to me. one brand had poor solder joints and lots of failures of their boards.
forced air furnace fan setting won't work turkish777 Electrical 31 03-14-2012 12:28 AM
Furnace Burners Flicker On and Off EDOinHB HVAC 19 02-22-2012 05:55 PM
Trane Gas Furnace - blower on but no flame at burners herbert8101 HVAC 2 09-24-2011 08:23 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
