Gibson Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2012, 02:45 PM   #1
gibson furnace
my indicator light says open limit circuit what should i try
tim schiess is offline   Reply With Quote
Old 11-05-2012, 02:49 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
First and foremost change your filter. High temperature limit switches trip due to excessive heat internal to the furnace, 99.999% of the time due to lack of air flow and of that, 50% due to a clogged filter and the other 50% a dirty evaporator coil.
You're going to need a meter to ohm out each individual switch to find out which one it is. Sometimes they are resettable, other times you'd need to have it replaced.
Thanks.
Doc Holliday is offline   Reply With Quote
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 08:13 AM
Gibson Furnace, IAQ and Skuttle humidifer connection skibum69 HVAC 15 12-08-2010 05:15 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
