GFI Outlet Requirement - HVAC - DIY Chatroom Home Improvement Forum
Old 06-27-2011, 12:30 PM   #1
GFI outlet requirement
Does anyone know if there is code requirement for a GFI outlet in the vicinity of outdoor air condenser (for AC) units? I am in Massachusetts. And if so what is the minimal distance? Thanks.
ninghai is offline   Reply With Quote
Old 06-27-2011, 05:20 PM   #2
Retired from the grind
Rewards Points: 6,652
Is the outlet outdoors? If you re-read your post, I am sure that you can figure out the answer to your question ninghai. Distance should be really at the same spot that the disco for the outside unit, not clear across the yard to the front outlet, or garage 200' away.
Old 06-27-2011, 05:34 PM   #3
Supposed to be one within 25' of the AC.
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
