Getting New A/C System Looking For Some Guidance - HVAC - DIY Chatroom Home Improvement Forum
Old 10-04-2012, 06:54 PM   #1
Getting New A/C System looking for some guidance
I知 thinking of getting an air conditioner system looking for either central or split unit. The house is locates in los angeles and it's 1100 sq ft, 2 br,1 bath, kitchen, dinning/living room all new windows and plenty of space in the attic for ducts and access to all the rooms.
I知 trying to figure out what is it that I need or what to look for in the quotes so i can make a good decision on what system to get.
my budget is around 2500 to 4000
thanx is advance
JL
jl2009 is offline   Reply With Quote
Old 10-04-2012, 07:18 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
good luck getting a system installed (including duct work) for less than 4k.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-04-2012, 07:35 PM   #3
Rewards Points: 582
thanx is advance
JL
only way to find out if you have enough in your budget get a few local bids.....best bet.....our guessing will only lead to disappointment...ben sr
Old 10-04-2012, 07:44 PM   #4
The budget I have in mind is just starting point it not set in stone but I don't think I want to spend anymore then 6k
Old 10-04-2012, 07:55 PM   #5
Rewards Points: 582
ok sounds good see post #3
Old 10-04-2012, 08:03 PM   #6
Missouri Bound's Avatar
Use 6K as your starting point....then when you get the actual bid you won't pass out!
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
ben's plumbing (10-04-2012)
Old 10-04-2012, 09:28 PM   #7
Plan on 30K then when it's lots less you'll feel all warm and fuzzy.
Old 10-04-2012, 11:45 PM   #8
Rewards Points: 616
30 k hope not....
carmon is offline   Reply With Quote
Old 10-05-2012, 04:43 AM   #9
An old Tradesmen
Rewards Points: 6,870
A contractor that does a load calc.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (10-05-2012)
Old 10-05-2012, 12:20 PM   #10
Yeah i hope is not 10K for a central unit! or else i will just go with a mini-split unit.
Costco has a promotion on Lennox unit I will give then a call for a free in home estimate and go from there and compare quotes once i start shopping around
Old 10-05-2012, 12:35 PM   #11
AKA HVACTECHFW
Lol! !
IT IS WHAT IT IS
Old 10-05-2012, 06:47 PM   #12
I think you may be able to get it installed under 10K. Get 3 bids at least and make sure that the companies have references and good reputations. If your neighbors have similar size homes talk to them. See what they have and see who did the work. Word of mouth is very important.
Old 10-05-2012, 07:18 PM   #13
+1 for what Missouri said about referrals.
Also, don't fall for "sign today and I will give you $xxx discount" sales tactic.
If the contractor is good, word of mouth referrals will keep him busy and will not have to resort to such pressure tactic.
Don't forget to check his license with your state.
good luck
allthumbsdiy is offline   Reply With Quote
Old low voltage lighting system - switches stopped working. zepman Electrical 14 02-17-2016 07:18 PM
A strange one - polybutelene piping used in radiant heating system GordCooper Plumbing 4 03-13-2012 10:09 PM
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 03:26 PM
Which heatings system should I go with? keano016 HVAC 5 12-01-2009 02:53 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
