Getting Humidifier To Run With The Furnace Blower, Not Just While Heating - HVAC - DIY Chatroom Home Improvement Forum
Old 10-19-2013, 09:01 PM   #1
Getting humidifier to run with the furnace blower, not just while heating
Hey guys.
I have a Heil DC90 central furnace with an Aprilaire 760 humidifier. The way the two are connected, the humidifier is connected directly to the manual humidistat and then it has a 120v plug which plugs into an outlet on the side of the furnace which is only energized during heating (HUM terminal). This means the humidifier is only able to run during heating.
This configuration is not always providing enough humidification.
The thought I had... My Ecobee thermostat has an option to "activate the blower with the humidifier when the humidifier is needed." Would this actually work? Or would the lack of hot air be ineffective?
Assuming that would be feasible, then I need to get the 120v outlet energized with the blower. Would switching it from the HUM terminal to the EAC terminal allow that to happen?
Thanks for any suggestions.
biglaz is offline   Reply With Quote
Old 10-19-2013, 09:18 PM   #2
Rewards Points: 920
Try it and let us know. I could see how this could over-humidify, but I guess the hygrometer or whatever will shut it down if it gets too wet?
Obviously the warm air is more gooder, but not absolutely necessary. A console humidifier doesn't heat up the air to run through.
cleveman is offline   Reply With Quote
Old 10-19-2013, 09:27 PM   #3
An old Tradesmen
Rewards Points: 6,124
Yes, it will work. You may have to connect the humidifier to the hot water line at teh water heater to gt enough moisture from it.
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 05:39 PM
Blower on Tempstar Furnace Barely Blowing Air psilva8 HVAC 7 12-07-2012 05:18 PM
furnace blower won't come on gulleyj HVAC 15 11-11-2012 04:16 PM
Replace furnace or blower agibby5 HVAC 6 07-17-2012 07:17 PM
Honeywell TrueSteam Humidifier Opinions/Experience dgbehrends HVAC 239 01-16-2012 04:08 PM
