Get Humidifier To Power On Only When Blower Runs? - HVAC - DIY Chatroom Home Improvement Forum
Old 02-02-2011, 04:46 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
get humidifier to power on only when blower runs?
Is there a proper way to hook up a 24vac load (or 120vac adapter, whatever is easier) so that it only runs when the furnace blower is running?
I'm sure I can figure somethin out, but just wondering if there is a standard way to do it. Can I just tap into the blower motor wiring, somehow, I don't think so because of the multi speed.
Old 02-02-2011, 07:06 PM   #2
An old Tradesmen
Rewards Points: 6,148
Tapping into the blower taps, will burn out the transformer.
You should have a HUM terminal that only energizes when the burner is running.
Old 02-02-2011, 07:16 PM   #3
Wire Chewer
Rewards Points: 46
Ahh was just going to ask about that terminal since I saw it and suspected it was designed for that. If I put my volt meter between that, and COM I get about 27 volts, when the furnace is in heat mode. So I can safely tap into that?
Old 02-02-2011, 07:28 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,166
Yes....
BEWARE for other readers of this forum, some units have a 120 volt HUM terminal as well as 24 volt HUM terminal. Make sure you test it B4 sticking your new humidifier wires to them.
Old 02-02-2011, 08:38 PM   #5
Wire Chewer
Rewards Points: 46
Good to know. Went to start installing the humidistat and realized the screws they provide are way too short (got to love that) and I don't have enough wire, so I'll have to continue tomorrow after a trip to BORG.
And yeah, always good to test voltage on anything and not just assume.
Old 02-02-2011, 08:47 PM   #6
I just installed a humidifier last weekend and mine runs on 24v. The Humd terminal on my board is 120v so make sure your meter in on V AC. Mine also and an EAC Electronic Air Cleaner so I used that. Now it runs when ever the fan is on.
DIY_HVAC is offline   Reply With Quote
Electric motor runs but lacks power. Mark Harvey Electrical 4 12-27-2010 12:26 PM
humidifier trouble water runs constant bjlffire HVAC 1 12-20-2010 03:17 AM
blower runs, with no heat captjack HVAC 6 12-14-2010 03:15 PM
Blower shuts off even when set to 'on' fetzer85 HVAC 1 07-05-2010 12:48 PM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 09:17 PM
