Geothermal Sizing - HVAC - DIY Chatroom Home Improvement Forum
Old 10-19-2012, 07:54 PM   #1
Talking
geothermal sizing
I am in the process of building my 2880 sq. ft. home. I would like to use geothermal heat with a lateral loop since I am on 2 acres I have plenty of room to make the trench. Can anyone recomend a length of inground loop for my house? I have learned about the coil method to conserve space, and since my backhoe has a 24" bucket this would be optimal. I've been told 450' but I was hoping for another opinion.
MikeFort is offline   Reply With Quote
Old 10-19-2012, 08:04 PM   #2
Missouri Bound's Avatar
Hey Mike (newbie)
What hvac knowledge to you possess? It take a bit more than digging a hole to install a geothermal system. Time to call an expert....(they may let you dig for them)
Do you want it your way or the right way?
The Following 3 Users Say Thank You to Missouri Bound For This Useful Post:
concretemasonry (10-19-2012), gregzoll (10-20-2012), joecaption (10-20-2012)
Old 10-20-2012, 09:39 AM   #3
Rewards Points: 16
Hi Mike
You will need 600 feet for every ton needed for your home. So if your unit is 4 ton you will need 2400 feet of pipe in the ground
Cheers
Alec
Alec is offline   Reply With Quote
Old 10-20-2012, 08:43 PM   #4
An old Tradesmen
Rewards Points: 7,318
The amount of loop length varies with the trench depth, and your soil. So there is no one length per ton.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (10-20-2012), gregzoll (10-20-2012)
Tags
geothermal , ground loop , sizing
Geothermal heat pump using pool as heat sink mnschu HVAC 9 05-17-2012 08:10 PM
Geothermal heating/cooling? Badfish740 HVAC 6 03-15-2012 08:43 AM
Sizing a dual shut off valve for a water line to fridge ericman Plumbing 10 08-19-2011 09:47 PM
Geothermal recovery against house foundation dirtman HVAC 0 01-05-2011 01:54 PM
Electric heat prices vs. geothermal mss119 HVAC 23 04-07-2009 07:23 PM
