Geothermal Recovery Against House Foundation - HVAC - DIY Chatroom Home Improvement Forum
Old 01-05-2011, 02:54 PM   #1
Geothermal recovery against house foundation
I live in Minnesota, the land of snow and ice. Geothermal heat recovery sounds like a great concept.
I am building a new home with R30 ICF walls all the way to the rafters, with R70 celings, this spring. We are required by code to put footings at least 4' below grade for frost. Some parts of my basement will be 7' below grade. IF it were prudent, I would not be opposed to digging another 3' down for the footing placement, and adding that much to the height of the walls, and then, instead of digging entirely new trences for geothermal slinky's, just using EPS pegboard grid mounted against the outside of the foundation for direct installation of the geothermal transfer grid.
(for example: http://www.barnworld.com/sa/p/Crete-...nel_System.htm)
Any feedback?
I am wondering a little about only being able to draw earth energy from one direction laterally . Is this a problem? Can it be overcome by just adding a reasonable amount more transfer looping? On our floorplan, assuming 8" spacing between the lines on 3' vertically of perimeter wall, buried at a depth of between 4-7', we would be able to place about 2600' of tubing on the wall. If this is practical, it could really save alot of expense in a geothermal installation. All you need is to dig a little deeper for the footings while you are at it anyway, and add a little more height to your wall.
Also, does anyone know of a thermally monitored geothermal installation, where they have documented the ground temperatures of the geothermal mass relative to the recovery loops? Is there a report of this somewhere, with thermal schematics? That would be very interesting. If the thermal movement is much more horizontal (heat drawing horizontally from the recovery loop) than vertical (heat drawing from beneath the recovery loop and rising like we normally assume heat moves), that would clearly be a major strike against mounting on the wall as opposed to in a separate trench away from the insulated wall.
dirtman is offline   Reply With Quote
Fire ants coming into house through pipes in foundation -- need advice samalex Pest Control 15 03-22-2011 02:35 PM
Foundation Issue - House Heaves in Cold Weather Lewes Building & Construction 1 10-12-2010 10:20 PM
Should I bolt my tri-level house to the foundation? SeattleDuck Building & Construction 2 10-16-2009 05:50 PM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 11:26 PM
House Foundation Painting jwags Painting 3 09-26-2009 01:48 PM
