Old 11-05-2007, 04:14 PM   #1
Default Geothermal loop pump size?
I am getting ready to start a DIY geothermal project and I want to double check something with you guys here.
My system will be closed loop horizontal with SDR11 3/4" pipe. There will be 6 loops of 500' each for a total of 3000' plus my 40' of 1 1/4" header. I will have a mixture of 25% Dowfrost(glycol) to 75% water. As far as the ft/head, there will be basically no difference in vertical level as my pipes will exit via my basement walls. I want to size my circulation pump correctly. My system has a 2 stage compressor and at full load the capacity is 5.5 tons. Figuring for 3.0gpm per ton I need about 16.5 gpm. What size pump is recommended? I am looking at the Grundfos U26-99f. This might be a little oversized but I want to be certain.
Any thoughts or suggestions would be appreciated. ST.
southerntester is offline   Reply With Quote
Old 11-05-2007, 07:54 PM   #2
Thoroughbred Mopar Man
Hi southerntester
You got kind of a loaded question there. Here is the skinny on the pump systems. You are going with closed loop in your post. However there are true closed loop and there is what some call closed loop that actually uses a pump center with a resivoir. If you are going with a true closed loop the pumps can be sized more for the actual maximum needed gpm. Let me explain. In a true closed loop system you have less resistance because the system is under about 40 psi of pressure and a constant volume control without having to overcome the effects of the atmosphere. This is the method I most prefer because you have less likely hood of outside contamination and very little water loss. If you use a flow center you will want to upsize the flow requirements by about 25% due to atmoshpere changes. The changes that most effect this are thermal. On this type of set up vescosity changes are more prone, this is why I reccomend upsizing the pumps. Not everyone agrees with me on this, but I have never had any call backs in the middle of winter or summer using this method. I promise you that you will thank me if you follow my advice. As far as the rest of it, the heat pump has a flow regulator built into it that runs off of the head pressure of the compressor. Just make sure you do not scrimp on the loops, and do not use the slinky loop design. This is not the best way to do a loop.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Old 11-05-2007, 10:02 PM   #3
Thanks for the reply Carrierman, I really appreciate it.
I am going to use an actual closed loop with an expansion tank but no reservior. My groundloop will actually be oversized a little as I will have 3000ft in the ground and I really don't need that much.
Thanks, ST.
Old 05-23-2009, 10:52 PM   #4
Default I used a QT Flow Center
I have a 2.5 ton Mcquay geothermal heat pump with a horizontal closed loop installed, the pump is a nonpressurized QT flow center, it was very simple the unit purges itself, I purchased my complete geothermal heat pump kit from Ingramswaterandair.com , they were very helpful!
Hop this helps!
Jasing is offline   Reply With Quote
Old 09-12-2009, 11:23 PM   #5
_working_
Jasing
I'm thinking of using the 5 ton version of the Mcquay from Ingramswaterandair, how did your project go? Do you like the system? How is it performing? I'm looking for references before I take such a big jump.
dennis.hurst is offline   Reply With Quote
Old 11-01-2009, 01:13 AM   #6
Question geothermal
Jasing
I was thinking of getting a system from Ingramswaterandair as well, how much cost was your system above the kit from ingrams? also what kind of savings do you gain?
koolkris is offline   Reply With Quote
Old 11-01-2009, 01:13 PM   #7
Yoyizit's Avatar
Pump equation
GPM = HP(40xEFF)/HD
HD= HP(40xEFF)/GPM
EFF = GPM(HD)/40(HP)
Efficiency is typ. 60% but is sometimes shown on the pump curve
HD is in feet.
Pipe loss example
http://www.engineeringtoolbox.com/pe...oss-d_619.html
Cold water in plastic pipe,
ID = 0.5", 4.8 GPM, 5 ft/sec, 8.8 psi drop per 100'
More On This Topic
When you need to pump water to a distant field, sometimes it's not convenient to run the pump with electricity. In such an application, a solar pump works well. Fortunately, you can do this yourself. This eHow can help you get started. Read More »
Welcome to Bead Bar in Orlando, Florida my name is Sonia and on this segment for Expert Village we are going to discuss wire a little bit. What we are going to do is this first technique we are going to show you is wire looping. Okay, now when it comes... Read More »
The next knot we're going to do is The Duncan's Loop. It's a nice one, if you want to have a loop where your line is connected to your fly or your lure. Maybe it gives a little bit more natural movement through the water. So what we'll do is we'll go... Read More »
The reason we have stopped is the filter has a lot of pressure on it and we need to backwash it and the reason it has pressure is because we're sucking these contaminants up and taking them to the filter so that they don't get back into the swimming pool... Read More »
Hi my name is Jeff Fiffie. I'm showing you how to move and replace a fuel pump on a Lincoln Continental. The first thing you want to check is your oil ring, checking it very closely to make sure there's no dry rotted. There's more cases when you receive... Read More »
Twin Impeller Shower Pump Connectors snowman23 Plumbing 1 11-11-2007 06:33 AM
bad comments/ geothermal toni HVAC 10 08-22-2007 01:29 AM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 05:08 PM
Wiring 240v pump to generator - URGENT Benchr Electrical 4 12-19-2006 07:50 PM
Well pump issue-should I be concerned? Mikedks Plumbing 8 10-09-2006 12:42 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
