Old 06-10-2008, 10:41 AM   #1
Geothermal hot water
I have a new installed geothermal system, closed loop system that was professionaly installed. Along with that two 50 gallon hot water heaters (electric). looking for ideas on why I run out of hot water quickly even when the geo unit is running. Basically if I fill a bath tub the hot water is gone.
Any ideas, thoughts or suggestions?
I did ensure all valves were turned on going from one hot water heater to the other.
prybar is offline   Reply With Quote
Old 06-10-2008, 07:09 PM   #2
electrical contractor
Are both water heaters wired/ plumbed and operating properly? What is the temp. setpoint on the heaters? I have one 40 gal heater and have more than enough hot water.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 10:24 PM
Low Water Pressure Eagle2 Plumbing 5 05-28-2008 11:29 PM
geothermal question robert smith HVAC 2 01-17-2008 09:48 PM
Help! Water Problem no one can solve! Goonky Plumbing 4 12-24-2007 10:03 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
