Geothermal Heat Pump Installation - HVAC - DIY Chatroom Home Improvement Forum
Old 06-05-2008, 11:42 AM   #1
Question
Geothermal Heat pump installation
I have read a lot about Geothermal heat pumps and one thing I haven't had explained is the term "header". I was going to put a closed loop system in for my house and it doesn't say anything about a header in the installaton instructions. Tell me if I am missing something. I haven't started anything yet. Thanks for any information you can provide. Brian
Brian Collins is offline   Reply With Quote
Old 06-05-2008, 05:52 PM   #2
I have not installed a system yet and not an expert but I suspect it will look something like this but on a smaller scale for residental installs.
http://www.geothermalsupply.com/headers.htm
My understanding is the ground loops will tie into the headers, you would have 2 headers one for water in from the loop and one going out to the loop.
smcmurrey is offline   Reply With Quote
Old 06-14-2008, 09:23 PM   #3
Rewards Points: 150
header
a header is what distributes an single closes loop to multiple shorter loops this is recomended especialy in a verticle or angled system you wont have to drill as deep and this allows more constant temps and drecreases the posobility you will hit bedrock remember to space the loops at least 2 feet apart so the heat emitted or obsorded by one line dosnt effect the other
geo fan is offline   Reply With Quote
Old 06-14-2008, 09:29 PM   #4
I found a better picture of what they look like. Mine came in and looks similar to these. Mine has a 1.25" inlet and goes to three 1" outlets for the field lines.
http://www.geohydrosupply.com/store/...hort%20Headers
Old 06-19-2008, 06:32 PM   #5
Rewards Points: 150
water
those are for a water source system the refrigernt source look more like a octopus and are copper
Old 06-21-2008, 07:22 AM   #6
Thank guys for the help
Tags
header?
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 12:27 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 02:51 PM
geothermal heat pump compressor frost up cbprov HVAC 1 01-15-2008 01:47 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
