GEO A/C Units - HVAC - DIY Chatroom Home Improvement Forum
Old 02-27-2011, 02:35 PM   #1
GEO A/C Units
Hi, we are having (6) 6 ton units put in in Saint Cloud Fl 34772 Earth Temp 73. I would like go with Well water BUT do to the water I must use a Titanium Heat Exchanger at the cost of $3,000.00. Do you think i should go with the ground loop of the well water open loop to the heat x and closed loop to the units. Thank.
Robert Farinato is offline   Reply With Quote
How to compare HVAC units of diff efficiency and same capacity tomseeley HVAC 3 03-13-2010 06:11 AM
Need HVAC solution for basement - 3 zone? or ductless units? skylake HVAC 2 10-06-2009 08:42 PM
Stacked washer & dryer units janralix Plumbing 4 08-06-2009 05:00 PM
5 ton unit or 2 seperate units allenky HVAC 1 06-06-2009 06:35 PM
Need to build enclosure for multiple outside a/c units. firedudesgirl Carpentry 4 03-31-2009 07:10 PM
