Old 11-17-2010, 08:58 AM   #1
Are "Genuine OEM" replacement parts necessary for a furnace?
Hi everybody,
We have a Trane XE70 gas furnace, original with the house (~22 years). I hired an HVAC tech to perform seasonal maintenance and inspection. He recommended the capacitor be replaced, because the reading was slightly below the "acceptable" threshold. He also noticed the blower motor was making a "clanking" noise at start-up and shut-down, which he believed was a bearing going bad - and recommended replacement of the blower motor as well. Due to the age of the unit, his final recommendation was replacing the entire furnace.
I found a web site that sells "Genuine OEM" Trane replacement parts specific to my furnace model. However, the prices of these parts are a LOT higher than generic/no-name parts on other sites.
Is it necessary (or recommended) to replace with OEM parts? Due to the age of my furnace, is it worth replacing these parts at all, if we plan to purchase a new furnace next year?
Thanks!
hvacdiy is offline   Reply With Quote
Old 11-17-2010, 10:59 AM   #2
I would buy a new high efficiency furnace this year and take advantage of the tax credits and rebates available until the end of this year instead of waiting until next year when there will not be any monetary incentives.
kb3ca is offline   Reply With Quote
Old 11-17-2010, 09:15 PM   #3
HVAC / Plumbing
On those 2 parts. I wouldn't use OEM. I stock emerson motors & xxx caps for replacments
kenmac is offline   Reply With Quote
Old 11-19-2010, 10:09 AM   #4
Thank you both for the responses. I'm getting a few estimates next week on a new high-efficiency furnace, and then I'll crunch some numbers.
Purchasing a replacement furnace fearless HVAC 15 07-24-2009 08:09 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 11:03 AM
Cosmetic Replacement of Tub/Shower Parts MrBill_DIY Plumbing 4 06-07-2008 06:53 PM
can't find old replacement parts, need Air Handler coils, junkyard? sammibah HVAC 2 07-02-2006 08:43 AM
singer replacement parts? billc1972 HVAC 2 01-11-2006 07:43 PM
