Generic Tempstar Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 08-16-2011, 05:53 PM   #1
generic tempstar furnace
my air cond wont blow. no output from 24v transformer. replaced transformer and still had the same problem. metered the input had 120 between black and white but still nothing from 24v side. if i connect the black primary and then ground the white to simulate a neutral i can get the outside unit to go but no blower. the neutral returns to a relay thru a jumper board. do i have an internal neutral problem, blower motor problem or is the relay associated with the problem?
electricranger2 is offline   Reply With Quote
Old 08-16-2011, 06:23 PM   #2
Rewards Points: 6,652
What about the contactor in the outside unit. If you push on it, does it fire up, when there is a call for a/c? Also, the capacitor can go bad, is that bulging? It looks like a soda can.
Old 08-16-2011, 06:30 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
neutrals NEVER go thru a relay. post a pic of the wiring or look at the original wiring diagram on the back of one of the doors and wire it back to original specs.
The Following User Says Thank You to yuri For This Useful Post:
electricranger2 (08-17-2011)
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Manual for Tempstar furnace ? Where? cody21 HVAC 1 04-05-2010 12:04 PM
Tempstar furnace is rumbling when burner is off ?? digitop HVAC 2 12-07-2009 06:39 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
