Generator - HVAC - DIY Chatroom Home Improvement Forum
Old 06-12-2010, 02:42 AM   #1
generator
is it possible to enclose a generator with the muffler left inside and if so how would i construct the enclosure to get the proper ventelation would leaving the bottom open and a fan be enough.thanks in advance
joe0508 is offline   Reply With Quote
Old 06-12-2010, 04:12 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
A portable generator produces a lot of very poisonous carbon monoxide, not to mention fire-hazard heat, and I would not enclose it if it were me.
Mine sits year-round on a covered. but open, side porch and I keep the windows and doors tightly closed on that side when using it.
If you just want a secure place to store it as well as use it, I would build a small shelter with a metal frame, metal roof and chainlink "walls" and locked gate.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-12-2010, 06:57 AM   #3
An old Tradesmen
Rewards Points: 6,088
Can't terminate the exhaust inside of an building/structure.
While the hot exhaust will be lighter then air. It won't all go outside through your openings. The exhaust will need to be extended out of the building. And then an air intake vent installed. Sized at about 300 sq in for every gallon of oil, or gasoline the generator uses an hour.
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 12:59 PM
Need Help Honda EU 2000 generator wiring problem rickytz7111 Electrical 10 11-23-2009 10:18 PM
Well Pump to Generator Question Sprice Electrical 1 02-11-2009 12:27 PM
Generator and Neutral Bonding Issue bradeng Electrical 6 12-09-2008 11:24 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
