General Temperature Question - HVAC - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 06:33 PM   #1
General temperature question
When my air kicks on it seems to take a while to lower the temp just 1 degree so the air is on longer. Is this normal? Its an 1100 sq foot house, 2.5 ton system. Also, when the suction line enters the condensing unit should there be continuous insulation because it drips for about the last few inches.
markharmon is offline   Reply With Quote
Old 05-20-2013, 06:44 PM   #2
Rewards Points: 616
yes its normal...... insulate the last 6 inches if you want..... wont make any difference other than it will not drip.....
carmon is offline   Reply With Quote
Old 05-20-2013, 06:59 PM   #3
What about the other part of my question?
Old 05-20-2013, 07:03 PM   #4
yes it's normal answered the first part
Old 05-20-2013, 07:13 PM   #5
My attic only has about 3 inches of insulation. I plan on adding another 6 inches. That is the most I can spend. Do you think that will make a difference?
Old 05-20-2013, 07:20 PM   #6
Yes. Seal all the holes from electrical wiring and plumbing first.
Old 05-20-2013, 08:50 PM   #7
Acoustical sealant good for that?
Condensation amyevans Windows and Doors 6 10-21-2011 11:11 PM
Condensation on Windows (PICS) - Advice Please livinginthepark General DIY Discussions 16 12-20-2010 08:35 AM
general hvac question dc21 HVAC 1 04-03-2010 01:03 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Temperature correction question koomo510 Electrical 5 10-17-2008 02:34 PM
