General Aire 1042 - HVAC - DIY Chatroom Home Improvement Forum
Old 10-02-2008, 11:52 AM   #1
general aire 1042
Hello, could someone give me instructions on how to change the evaporator pad on my humidifier. Its been a few years and I think I should it yes?
bullet is offline   Reply With Quote
Old 10-02-2008, 12:21 PM   #2
1610 CUB's Avatar
Rewards Points: 150
Is that a by-pass type? If so the bottom will have a screw you remove and the core will drop down and out. But if the drain is in the was you may have to remove the top but be very careful of the water line, and depending how long its been there the water shutoff won't work (at least they never would for me) any was get the top to move aside and pull the core up and out. ( do what ya got to do to move the drain)
1610 CUB is offline   Reply With Quote
Old 10-02-2008, 08:01 PM   #3
The internal humid. pad can be accessed thru the top or bottom.
The bottom is preferred. Remove two 1/4" screws on each or two slides (depends on age of humid) side of drain trough and be careful not to spill water on your self as the is always some water left in the trough.
Let the drain trough hang by the drain tube or remove from drain line and set to one side.
You will know see the pad. Pull it straight out. Before replacing new pad clean the drain trough throughly. Germs can abound in the trough.
Slide in new pad a replace drain trough on to humid.
Change pad seasonally
hvaclover is offline   Reply With Quote
Old 10-02-2008, 09:54 PM   #4
thanks guys,
the guy that installed it told me there was no maintenance required.
i kow by now there's no such thing, thanks
on a side note where can i get the pad?
i just got back from hd, lowes, canadian tire, nobody has the part?
Old 10-02-2008, 11:20 PM   #5
Originally Posted by bullet View Post
thanks guys,
Maintenance free in that you don't have to clean a scummy water pan.
You can only gt the pad from an HVAC dealer or parts seller.
Change every heating season.
Clover
Old 10-03-2008, 12:48 AM   #6
ok thanks again
General Contractor fees Luvbug Off Topic 15 08-21-2013 09:28 PM
general DIY advice? Ronny88 Remodeling 21 03-19-2012 03:31 PM
General contractors license. raymond_anthony Building & Construction 5 08-20-2006 05:07 AM
