General 1042L Power Humidifier - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2010, 05:57 PM   #1
general 1042L power humidifier
Hey everyone. I have a problem. its getting to be winter time and my Ducane Furnace has a general model ac-1 air cleaner with a general 1042L power humidifier. now that the furnace is running more i lately have a build up of water. i had a repair man come over and check it out and the vent lines on the furnace had become back filled with water and the furnace would not ignite. drained the lines and works great. recently the furnace shut down again and water was leaking out of the furnace and the vent lines were plugged again. what is causing the drain line not to drain and the vent lines to clog.
Billkee1 is offline   Reply With Quote
Old 11-30-2010, 07:52 PM   #2
An old Tradesmen
Rewards Points: 6,576
Could be a dirty trap.
The Following User Says Thank You to beenthere For This Useful Post:
Billkee1 (12-01-2010)
Old 11-30-2010, 08:27 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
could be a slow drain due to biological growth in the pipe. Biological growth or algae or other stuff could be partially blocking the pipe, you said that you drained the lines, did you blow through them to clear them or what do you mean exactly? Blow through them to ensure they are clear and then pour a cup of bleach down the pipe... this will help to kill anything growing inside the drain
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 08:26 PM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 09:17 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
I'm all about saving money on electricity but what is this? imola ghost Electrical 15 09-09-2008 09:36 PM
Humidifier & Thermostat BigD HVAC 1 12-19-2007 09:04 PM
