Old 11-25-2010, 06:58 PM   #1
are ge zoneline units compatible with each other?
Hi i am looking to replace an old ge zoneline ptac in an investment property. My building management said the compatible unit is this one:
https://hdsupplysolutions.com/webapp...-1&req=catalog
But it's kind expensive, can i use this one below? will it be compatible for installation?
thank you
gagaliya is offline   Reply With Quote
Old 11-25-2010, 09:52 PM   #2
An old Tradesmen
Maybe. Did your old one run a lot, and for long times periods?
If so. that smaller one, won't cool your place, and won't shut off very often, once it gets hot outside.
Old 11-26-2010, 09:08 PM   #3
it's a small room so i think it's more than enough for both heating and ac.
Do you know for sure they are compatible with each other in term of installation? I dont want to have this big thing shipped across country only to find out it cant be installed.
thank you
Old 11-27-2010, 04:24 AM   #4
An old Tradesmen
They aren't the same physical size.
The first one is 45" deep X 18½" high X 25 1/3" wide.
The second one is 13¾" deep X 16" high X 42" wide.
So you aren't going to be able to switch which one, with out some major rework.
Hiding outdoor A/C units artlover13060 Landscaping & Lawn Care 4 03-09-2010 07:23 PM
Need HVAC solution for basement - 3 zone? or ductless units? skylake HVAC 2 10-06-2009 08:42 PM
are central air units compatible with any furnace? firsttimeowner HVAC 3 08-10-2009 09:15 AM
Stacked washer & dryer units janralix Plumbing 4 08-06-2009 05:00 PM
5 ton unit or 2 seperate units allenky HVAC 1 06-06-2009 06:35 PM
