GE Weathertron Rooftop Horizontal Heat Pump 1883 - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 12:14 PM   #1
Still working good but compressor reading 430 volts, AC guy says shold be around 370 volt. He recomends replacing entire unit but I would like to replace the compressor. Has new squirl cage, blower, blower cap and blower relay, also replaced compressor cap. Where can I get a compressor for this unit?
lab123chr321 is offline   Reply With Quote
Old 07-14-2012, 03:12 PM   #2
An old Tradesmen
Rewards Points: 7,388
Guessing he took that voltage reading across the run cap. If its not the original capacitor. good chance someone put in the wrong voltage cap. And it really should be reading around 440 volts.
Old 07-14-2012, 09:07 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
that is no way to tell what kind of shape the compressor is in........ To check compressor windings integrity you need a megohmmeter.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 07-14-2012, 10:14 PM   #4
Missouri Bound's Avatar
Is that a 20 year old heat pump? I'd consider looking for replacement.
Do you want it your way or the right way?
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 07:48 PM
Heat pump and Honeywell 8000 questions. jyoderz HVAC 14 04-06-2010 02:26 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 09:14 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
