GE A Coil Help Needed - HVAC - DIY Chatroom Home Improvement Forum
Old 05-24-2010, 11:17 AM   #1
GE A Coil help needed
Hi All,
Great forum you have. I have an old (1978) GE A coil unit removed from one of my split systems. I'm curious if anyone has the ability to help me source a replacement?
The A coil was found to be leaking and my infrequent A/C guy told me 1500 labor to replace. A bit much I thought.
I got the old unit removed this morning, an hour or so, and now need to source the replacement.
Thanks in advance!
ID number - 8BXA036A208A0
DATE-122
PSI- 150
R-22
MRRiley is offline   Reply With Quote
Old 05-24-2010, 02:04 PM   #2
An old Tradesmen
Rewards Points: 7,268
Ain't none. GE hasn't made a central A/C system since 1983.
Old 05-24-2010, 05:41 PM   #3
Based on this units longevity, I'd say that's a shame.
The dimension of the uncased coil are 17H x 19w x 20d. Fittings are on the right looking at the coil. I believe its a 3 ton unit. Any generics perhaps?
Old 05-24-2010, 06:36 PM   #4
Running low on refrigerant could have damaged the old compressor. Sure you want to put a $600 coil on a 32 year old AC?
Old 05-24-2010, 06:55 PM   #5
I've been told that there is a possibility of having to repair the compressor, if that becomes the case I will.
What I don't have is unlimited funds to drop the latest, greatest, high dollar, ultra efficient system in place. If i can find a workable coil to replace the one I have, I have the tools, training and experience to do the install. Then, if by chance the compressor is bad, I can replace that too.
The coils I have tracked down are no where near 600, more like about half of that. I asked for a recommendation to source the part required on the assumption that there are many other knowledge, mechanically inclined individuals who don't have the bucks, but do have the time to work the repair. This seams like a place for kindred spirits.
Old 09-25-2010, 04:47 PM   #6
Alpine heat and air has a replacement for u
robert wadford is offline   Reply With Quote
Evaporator Coil Sizing kandykane19 HVAC 0 05-05-2010 03:44 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 09:27 AM
Air conditioning coil heat tolerance? Badfish740 HVAC 1 10-19-2009 05:39 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Evaporator coil for Goodman A/C leschuler HVAC 2 09-25-2008 12:43 PM
