Ge Blower Motor In Carrier Seizes When Power Applied - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2010, 11:14 AM   #1
Ge blower motor in carrier seizes when power applied
I have a rooftop carrier unit the blower motor is 3 phase spins free when off ...power on and seizes up trying to start could it be the cap how do you test?
kenfranciose is offline   Reply With Quote
Old 12-19-2010, 12:56 PM   #2
Three phase is not something a DIY should mess with. It's many times more dangerous then household voltage'
THE FACT YOU ASKED IF IT HAS A CAPACITOR SHOWS YOU LACK THE PROPER UNDERSTANDING TO GO FORWARD WITH THIS REPAIR.
hvaclover is offline   Reply With Quote
Old 12-20-2010, 01:28 AM   #3
blower motor cap
i asked how do you test a cap on a 3 phase? but thanks for your intelligent response... can't read huh?
Old 12-20-2010, 01:31 AM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you don't have a cap on a 3 phase motor. That's the beauty of 3 phase. You don't need to artificially shift the sine wave to create an offset wave.
Old 12-20-2010, 01:40 AM   #5
thats where my confusion is it says 208/240 2o8/400 3 phase and there is a cap
Old 12-20-2010, 02:20 AM   #6
nap
You talking to me?
nap's Avatar
I'm confused as well.
To test a cap, I grab my trust cap tester and hook it up. There are methods to check the general condition of a cap without one, an actual cap tester is the only way to determine if the cap's capacity is proper.
Old 12-20-2010, 02:53 AM   #7
Please don't mouth me...I know how to repair 3 phase and I know how to check a cap.
That's why you are looking for advice and I am here giving it to folks who ask.
Old 12-20-2010, 08:23 AM   #8
Rewards Points: 640
Doesn't "208/240 2o8/400 3 phase " mean it works on 240 2 phase and 400 3 phase if wired correctly? Are you sure its wired as a 3 phase? if there is a cap its wired as a 2 phase
BlueBSH is offline   Reply With Quote
Old 12-20-2010, 04:40 PM   #9
nap
You talking to me?
nap's Avatar
there is no 2 phase in use in the US that I am aware of. I suppose there might be some special use stuff somewhere but (and the generating plant at Niagra Falls even used to be) but I do not believe there is anymore in general use.
You have single or 3 phase.
Old 12-20-2010, 04:41 PM   #10
Rewards Points: 640
sorry, I mean single don't know why I wrote two was thinking hot wires not phases
Old 12-20-2010, 04:43 PM   #11
nap
You talking to me?
nap's Avatar
a lot of people do the same thing when using 2 legs of a power supply. You aren't the only one that does it.
Old 12-20-2010, 04:47 PM   #12
Rewards Points: 640
I think the thing that trips me up is my service panel calls it "Phase A" and "Phase B" which makes you think in your head its two phase when its really leg 1 +120v leg 2 +120v
Old 12-20-2010, 08:54 PM   #13
An old Tradesmen
Rewards Points: 6,086
Also know as split phase. And sometimes poly phase.
Old 12-20-2010, 08:56 PM   #14
An old Tradesmen
Motor run capacitors are cheap. Go out and buy a new one. Install it, and see if the motor runs.
The other way to test it. is to use a capacitor tester.
Old 12-20-2010, 09:46 PM   #15
Forgot about poly phase. My bad.
carrier furnace...no heat blower won't stop kevinp HVAC 19 11-13-2014 11:37 PM
Power Save Device capt2 Electrical 52 02-24-2010 07:42 PM
HELP! Carrier Weathermaker Infinity Not Working! MaxPierre HVAC 27 01-19-2009 07:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
