Old 11-24-2012, 08:46 PM   #1
Gauge on oil furnace
what does the gauge on an oil furnace measure and does it matter that it stopped working after they replaced the circulator
Granty is offline   Reply With Quote
Old 11-24-2012, 10:59 PM   #2
First of all it is a boiler you are referring to not a furnace...the pressure gauge should show some pressure....Are you getting heat?..if so, could be a coincidental gauge failure OR just maybe stuck..try tapping gauge to see if needle moves...if not, let us know answers to above Q's before we proceed any further. also, sometimes gauge needle can bounce back over zero pin preventing it from moving..then remove glass cover and release needle from behind pin (if it is not an oil filled gauge which I doubt that it is) let us know after you check. Thanks
techpappy is offline   Reply With Quote
Old 11-25-2012, 05:11 AM   #3
An old Tradesmen
Stopped working after they replaced the circ? Could be it works, but they didn't put enough water back in.
It measures pressure and temp.
Furnace Interlocking for HRV mk5tdi HVAC 5 03-10-2012 02:27 AM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
