-   -   Gauge on oil furnace (http://www.diychatroom.com/f17/gauge-oil-furnace-164580/)
Granty 11-24-2012 08:46 PM
what does the gauge on an oil furnace measure and does it matter that it stopped working after they replaced the circulator
techpappy 11-24-2012 10:59 PM
First of all it is a boiler you are referring to not a furnace...the pressure gauge should show some pressure....Are you getting heat?..if so, could be a coincidental gauge failure OR just maybe stuck..try tapping gauge to see if needle moves...if not, let us know answers to above Q's before we proceed any further. also, sometimes gauge needle can bounce back over zero pin preventing it from moving..then remove glass cover and release needle from behind pin (if it is not an oil filled gauge which I doubt that it is) let us know after you check. Thanks
beenthere 11-25-2012 05:11 AM
Stopped working after they replaced the circ? Could be it works, but they didn't put enough water back in.
It measures pressure and temp.
