"gassy" Odor In One Room From A/c Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 01:48 AM   #1
Question
"gassy" odor in one room from a/c vent
Hi,
A while ago, we decided to turn our central air setting to "constant fan" thinking to keep the air moving around more, and to avoid the constant loud/quiet decibel level changes. After about a day of this, I noticed an icky odor, but in only one room, so we put the fan setting back to where it only blows when the a/c kicks on.
The smell, however, hung around, even when the a/c isn't on. It has gotten slowly worse, and now when I am in that room, the smell is constant rather than intermittent and elusive as it ws at first. I can only describe it as a sort of gassy smell, like, sorry, a fart. Since we sleep in this room, I'm getting concerned about health issues.
Neither husband nor I are/am very handy, but part of the unit is in the attic, including a big pan (that appears dry) which is easily accessible, so if there's something I can check, I can do that if it's described in layman terms.
What can this be?? And how would using the constant fan setting have set it in motion?
or should we just call an HVAC company (original,1993, installer long since retired)?
Thank you in advance for any thoughts, suggestions, and help.
NJinPA is offline   Reply With Quote
Old 01-08-2013, 05:57 AM   #2
Only one vent stinks probably means a dead critter in that duct.
furnace room vent dtw HVAC 4 10-30-2011 01:25 AM
One room cold- what pipes are what...help cciampi HVAC 24 02-20-2011 11:44 AM
Laundry Room Vent: slope up - then down LogDog Plumbing 3 12-31-2010 04:59 PM
tap into vent and run extra vent to room? denemante HVAC 0 11-11-2010 03:55 PM
installing a vent in the door to my hvac room brentjc HVAC 1 10-13-2010 06:10 PM
