Gas Won't Stay On - HVAC - DIY Chatroom Home Improvement Forum
Old 02-05-2013, 07:50 PM   #1
Gas Won't stay on
I have a Adams Speedflame and I have replaced the thermo coupler after I light the pilot it stays on and the flame comes on. However it only runs for about 30 Seconds and the whole thing shuts off Pilot and all? Please help it is getting real cold up here in North East Ohio
John Ginn is offline   Reply With Quote
Old 02-05-2013, 08:23 PM   #2
MarginallyQualified
Rewards Points: 2,464
I have replaced the thermo coupler <-- Why?
Assuming this has some sort of combination valve...
the pilot safety function is the obvious suspect.
What else is on the control circuit?
Can you measure gas pressure?
Old 02-05-2013, 08:42 PM   #3
Sounds like a chimney issue. What is you speedflame burner running? An old oil furnace I would imagine. Check for chimney blockage.
Also check the pressure, too much pressure and you'll blow the limit and all shut down.
furnacelady is offline   Reply With Quote
Old 02-06-2013, 08:14 AM   #4
Thank You so much for the information, I found out that the new thermo coupler was not in the proper place. It extended out too far from the pilot light. I pushed it back so just the tip was showing in the pilot flame and once again we are warm in North East Ohio.
Old 02-06-2013, 09:22 AM   #5
Roofmaster
Rewards Points: 2,172
Well yeah, that's how they work. Current flow due to the electrical properties of dissimilar metals.
Old 02-06-2013, 09:39 AM   #6
I know I am a dummy but it was the first time I worked on a furnace I knew what and how they worked. It happened when I was putting all back together again I forgot to use the little clip they provided and it slipped out of place.
Old 02-06-2013, 10:43 AM   #7
Roofmaster
Anybody can make a mistake. At least you got in there and did it, and fixed it. A dummy would have said "uuuggghhhhh whats a furnace?"
Old 02-06-2013, 11:17 AM   #8
Thanks Again for ervything
garage door won't stay closed albertkao General DIY Discussions 12 10-07-2013 11:26 PM
A.O.Smith gas water heater won't stay lit! stoney_870 Plumbing 3 01-25-2013 11:50 PM
furnace wont stay lit goatboy0067 HVAC 4 12-08-2012 09:21 PM
Heater will not stay on HAMP HVAC 4 02-10-2011 01:16 PM
gas value won't stay open on a goodman furnace gmpn100-4 kevinmargo HVAC 1 01-06-2011 01:34 PM
