Gas Will Not Ignite - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 11:32 AM   #1
Gas will not ignite
My furnace wil not light after the igniter turns on. After looking at the wire diagram I should be getting 24v on the gas valve after a few sec after the igniter turns on. The only voltage I'm getting is a very quick surge of voltage that I can not even read. should I replace the Gas Valve Relay on the circuit board?
Atchmoe is offline   Reply With Quote
Furnace fails to ignite now and then... diitto HVAC 7 11-23-2016 04:19 PM
Heil furnace won't ignite mjprel HVAC 24 10-23-2009 02:52 PM
Gas Hot water heater, burner will not ignite hammerdome Plumbing 8 10-14-2009 05:04 PM
Oil furnace does not ignite coldinil HVAC 12 01-25-2009 11:18 AM
gmp100-3 furnance won't try to ignite davewolf HVAC 5 11-21-2006 02:13 AM
