Gas Wall Heaters, What Do You All Think? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2009, 09:28 PM   #1
Gas wall heaters, what do you all think?
I have a kitchen that's a little colder than the rest of the house. Insulated and whar have you..........I'm thinking about getting a gas wall heater about 10k to take the chill off. Questions,,,,,,,,,,how effiecent are they, will a 10k warm a 14x14 room and how do you that have them like them? Also how much gas do they eat up?
Bearcamp is offline   Reply With Quote
Old 01-25-2009, 10:22 PM   #2
JohnH1's Avatar
What type of heat do you have in the home. Could you add additional heat from what you have or balance the system out better to heat the kitchen?
JohnH1 is offline   Reply With Quote
Old 01-26-2009, 12:12 AM   #3
I have oil baseboard hot water including the kitchen. But the kitchen is always a little cooler as the thermostat is in another room. If I were to move the stat to the kitchen then the rest of the house probably be too warm. Anyways I'm looking for a little extra boost to cut back on the oil furnace working so much. It cost me 400 bucks in 1 month to heat this place.
Old 01-26-2009, 05:55 AM   #4
An old Tradesmen
Rewards Points: 6,116
They're 80% efficient.
How much gas, depends on how much you use it.
Be carefull, if you just want a little extra heat. A 10,000BTU one, will be more then just a little extra.
Old 01-26-2009, 07:00 AM   #5
the Musigician
DangerMouse's Avatar
a friend of mine had one in a single story and he heated the whole place to 90 degrees with that little sucker.... it was like walking into an oven.
DM
Old 01-26-2009, 08:11 AM   #6
Rewards Points: 528
The gas wall heater is overkill for a 14 X 14 foot room that is just a bit cooler then the rest of the house. I suggest trying what JohnH1 says. Also a cheap alternative is to place an electric portable oil filled radiator in the kitchen. They cost about $40.00 to $60.00.
Don't buy anything from China. Look for American or European manufacturer. Check to make sure the U.L. label is on the unit before purchasing.
I used to have one of these in my basement which was much colder then my two story house. They are probally more efficient then electric heaters but my unit was unvented and the main product of combustion which is carbon dioxide increased the normal concentration to four to six times the outdoor level of 340 ppm. Now I said carbon dioxide, not carbon monoxide (the dangerous one) as some people still get the two confused. But still, carbon dioxide at high levels is not healthy.
rjordan392 is offline   Reply With Quote
Old 01-26-2009, 12:47 PM   #7
Rewards Points: 1,910
Sounds like you don't have enough length of hydronic baseboard in the kitchen or you aren't getting enough flow (or high enough temperature water) to the baseboard that's there. Rather than spend on a supplemental heater I'd try to get the existing btu output up in the kitchen by fixing what's wrong with it. As far as the cost of running the oil burner, if you have natural gas available then you might want to consider going to a gas boiler at some point.
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
What code covers installation of wall heaters? darsunt Electrical 6 08-09-2008 05:12 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
