Gas Vs. Electric Heat? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2008, 07:58 AM   #1
Rewards Points: 152
Gas vs. Electric heat?
Hello All,
I am planning to put in central a/c and forced air heat into my home (I have window units and hot water baseboard now (Oil Burner)).
When I look into getting the unit for the basement, should I be looking at gas furnaces or electric. Just wondering what the pro's and con's are of each.
Thanks!
sandyman720 is offline   Reply With Quote
Old 01-17-2008, 08:18 AM   #2
What is your electric rate? Unless it's very low (like well under 10 cents per kwh) you'll save a lot of money with a gas furnace.
NateHanson is offline   Reply With Quote
Old 01-17-2008, 07:10 PM   #3
Union HVAC Tech.
I would never in my life tell anyone to go from hotwater heat to hot air. The best jobs in the world are hotwater, the cheapest is scorched air. The pros and cons are endless. Allergies, hot air is bad. Comfort, hot air is bad, it has no residual your heating air while the burner is on and that's it, when you heat water it stays warm and has some mass to it. Add an a/c system, maybe get an upgrade on the boiler. If you go to hot air you will regret it in the end for many many reasons. Ask any one that has it, or better yet any one that has switched.
bigMikeB is offline   Reply With Quote
Electric radiant heat in the garage art2670 Flooring 4 01-26-2008 09:58 AM
Electric Baseboard Heat Skydmark1 HVAC 9 10-14-2007 09:03 PM
Electric vs. Hydrolic Radiant Heat art2670 HVAC 2 08-23-2007 04:51 PM
too much electric heat DIYtilIdie HVAC 2 07-08-2007 09:27 AM
Convert from electric heat to oil/propane? Badfish740 HVAC 7 05-15-2007 12:17 PM
