Gas Valve Wiring Question - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2008, 11:39 AM   #1
Gas valve wiring question
Hi,
My dad has a GE furnace (yes it's old) that the gas valve went out on. We went to supply house and bought a Honeywell vr8300a replacement.
On the old valve it had the TH/TR and M - M terminal points. The M - M was for a fusible link with two red wires coming from it. However in the new valve it TH/TR and then only Convenience terminals, not the M - M.
What is the proper way to wire this?
kramnation is offline   Reply With Quote
Old 12-01-2008, 06:28 PM   #2
An old Tradesmen
Rewards Points: 6,068
Wrong valve.
But, you can wire nut the wire that went to the TH terminal to one of the reds, and the other red then hooks to the TH.
Old 12-02-2008, 06:21 PM   #3
Originally Posted by beenthere View Post
Wrong valve.
Thanks! Works great!
Older wiring question... PirateKatz Electrical 8 11-25-2008 11:11 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
wiring recessed lights question. SubSailor Electrical 2 02-25-2008 01:39 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
