Old 01-01-2012, 01:04 PM   #1
Gas valve circuit error-furnace
I have an american standard freedom 80 comfort-r furnace.the burners will only light up for a few seconds and then will shut off. It continues to try and light up but with no success. According to the 7 flashing lights, it says that it is a gas valve circuit error.what can I do to fix this?
Jgolden is offline   Reply With Quote
Old 01-01-2012, 01:42 PM   #2
I'm Your Huckleberry
try cleaning the flame sensor. one wire to it, thin metal rod possibly shaped like an L that sits directly in the flame so look for it in the burner area. use a scouring pad like the green rough dish washing ones.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
plummen (01-01-2012)
Old 01-01-2012, 01:42 PM   #3
Locate, remove and clean the flame sensor........steel wool, Emory cloth or a fine grit sand paper
harleyrider is offline   Reply With Quote
The Following User Says Thank You to harleyrider For This Useful Post:
Old 01-01-2012, 01:43 PM   #4
I win.
Thanks.
Old 01-01-2012, 01:47 PM   #5
Professional
a 7 flash gas valve circuit error is that 24V is present on the gas valve circuit when it should not be. However, what you describe is not a symptom of a 7 flash error. Are you sure you counted the LED flashes correctly. What you have described sounds exactly like a dirty flame sensor as the others have instructed you to clean.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 01-01-2012, 01:59 PM   #6
Originally Posted by Doc Holliday View Post
I win.
The winner is the client that we are assisting.
Old 01-01-2012, 02:02 PM   #7
I meant "I win" because I snuck in my answer first.
Thanks.
Old 01-01-2012, 02:04 PM   #8
Congratulations, did you do a victory burn out? I was not aware that this was a competition.
Old 01-01-2012, 02:07 PM   #9
Never mind.
Thanks.
Old 01-01-2012, 02:09 PM   #10
Wow, that was just too simple.
Old 01-01-2012, 02:14 PM   #11
So the flame sensor was the problem?
Thanks.
Old 01-01-2012, 02:21 PM   #12
I guess so, it's working now. Thanks!
Tags
furnace
Dispute: Oven malfunction after h/w guys used the circuit rational Appliances 18 05-17-2011 11:37 PM
Cant get the valve off (with picture) clof2001 Plumbing 3 05-10-2010 04:04 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
